Ir para o conteúdo principal
A Ninja Coffee Bar CF086 é uma cafeteira com uma garrafa térmica de 43 oz (aproximadamente 1,27 litro) e tecnologia Auto-iQ One Touch Intelligence.
locate sensor inside CF091
i need to open up Ninja and locate the sensor and bypass, even on a full carafe after 3 seconds it beeps and stops brewing
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Probably not the sensor. It is probably clogged in the upper part before the spout. I have had 3 of these machines that all did that right after about a year…I finally figured out the problem.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Hi Brent! Were you able to unclog your machine? If so, would you be able to share how? Thank you!
por
Yes, please elaborate on how to fix this. Maybe cleaning with a pipe cleaner? Nothing seems clogged, though. The water comes out just fine. It just stops after a few seconds and beeps.
por
Adicionar a sua resposta
Sharon Dusenbery será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 19
Ao todo: 1,144
