Ir para o conteúdo principal
Estação de carregamento para o controle DualSense do PS5.
How to remove the white side plates
The dualsense charging station has white side plates like the Playstation 5 console. I want to paint them black, so I was wondering if there was a way to remove the white plates. There are no visible screws. The whole thing seems to be glued together.
Esta é uma boa pergunta?
Pontuação 3
1 comentário
did you ever find a way?
por
Adicionar um comentário
3 respostas
Pergunta mais útil
If you turn the charging station upside-down, on the bottom plastic you will see two edges which connect to the inside side and top plastic which is one moulding. Pry the bottom plastic off (it's just clipped) and then undo the screws and the white side plastic comes off.
Esta resposta foi útil?
Pontuação 2
See my teardown over at Dualsense Charging Station Tear Down Guide
Pontuação 2
So if you want to take the sides off your PS five you want to hold the PlayStation button press down and then up and then it’s off
Pontuação 0
Adicionar a sua resposta
Sulakshan Rajaratnam será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 53
Ao todo: 2,154
