Ir para o conteúdo principal
Guias de reparo, desmontagem e informações de resolução de problemas para o iPad da Apple de 6ª geração, disponível em versões Wi-Fi e celular com 32 ou 128 GB de armazenamento. Lançado em março de 2018. Identificado pelos números de modelo A1893 e A1954. Possui uma tela Retina de 9,7" e chip A10 Fusion de 64 bits.
Missing Pads Charge Port
Hello,
I am missing charge port pads for pins 5, 12, 14, and 20 for an iPad 6th Generation WIFI. Can some help me identify any test points on board where I can jump these to the connector?
Thanks in advance!
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 1
5 comentários
you need to mark the pads in the photo or picture - the numbers of pins and lines are not marked on any of the available diagrams (let's at least set the starting point and the direction of counting - so as not to make a stupid mistake). At the same time, I confirm - such a check is possible
por
I am missing the ones highlighted in light blue.
por
mmejia04 post a picture of your actual board as well. That way we can actually see the placement of the components and follow the traces as per schematic....
por
I posted a new picture, the pads inside the red boxes are the ones needed. The other pads are either connected to ground or have a second connection to the same point.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
hello there,
here you've got
Imagem
Esta resposta foi útil?
Pontuação 1
5 comentários:
Thanks for all your help!
por
I am sorry, I missed to add another pad, the one right next to the purple one.
por
no problem, pict upgraded
por
hi can i you help me to pin point positive and negative pin to charge the ipad 6th gen beacuse the pin was destroy im trying put jumper on it
por
Hi @bryanlutuaco ,
yes, of course. unfortunately, it is difficult to post anything in the comments section :-) So start a new thread and throw a link (preferably by email - you will find it in the "about me" tab) so as not to miss it in the thicket of other messages.
por
Adicionar a sua resposta
mmejia04 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 65
Ao todo: 1,784
