Ir para o conteúdo principal
Caps lock blink 5+3 motherboard failure due to power supply
I have hp 15-g dr0008u notebook pc and facing weird issue of motherboard failure.
When i start pc, as mentioned caps lock blinks 5 times slowly and then 3 times fast so as suggested on hp website this is something unintended with board failure.
So far i have already tried everything mentioned in hp website like hard resetting pc and trying to reset bios with windows+b/v key combination which none of them worked.
So seeing no hope i finally took it to nearest shop and repair adviced there is no proper voltage coming on IC due to some power supply module issue and it will cost me around 3500 inr which can be almost half of second new motherboard price.
I have also faced issues related to power supply earlier in this same year and this all costs me more money which anyone can't afford atleast within this time.
So the question is how hp manufacturer cares for their consumer about power supply distribution and this board $@$*?
Even when i did realise that the cmos battery is inside the main battery which can't be removed anyhow, now i am just thinking this could be nothing but business perspective.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
OK, listen, I'm simple terms, I got the back unscrewed. Now what? And don't come at me with all this ram card wifi motherboard magic $@$*. Tell me, “unplug the green one. Then push the button then plug in the cord, and unplug the yellow one. “ I'm an idiot. OK? Not a computer genius. I'm broke, just bought this brand new laptop, had it less than 2 months, need it for my new business, and I'm sitting here with a screw driver trying not to stab myself in the neck in frustration.
por
@Ashley Carter
If it is new why not take it back and get it repaired under warranty? That's what warranties are for.
Opening up has most probably voided the warranty.
There is a link to the service manual in the answer below if your laptop is the same model as listed above in the question. It will help, along with the answer to hopefully fix it.
If not try the warranty route, hopefully it will be honoured.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
I don’t know the service shop you went to but if it was me I would try taking out all accesory devices - SSD/HD, RAM, Optical drive, Wi-Fi card, battery, etc. Remember a fault or short in one of them could put the whole main board off.
Here is the link to the Service Manual:
http://h10032.www1.hp.com/ctg/Manual/c06...
Then with battery out and power supply/adapter connected try one RAM module at a time and try to start up. Anything? If nothing I guess the mainboard is defective.
If yes can you get into the BIOS/UEFI and run the built in HP Diagnostics as so:
  1. Turn on the computer.
  2. Immediately press the f2 key repeatedly, about once every second, until the UEFI menu opens.
  3. When the UEFI menu opens, select the diagnostic test you want to run, and then follow the on-screen instructions.
If that passes the test then try booting off of a bootable USB drive. Did it work? Yes? Then add the main drive and see if it boots up. No? Then drive is defective or corrupted.
Good luck my friend.
Esta resposta foi útil?
Pontuação 3
3 comentários:
@aactech thanks for your reply man.
Update as of today.
Repairer said my IO device was failed and it costed me even more than expected. Btw I did all the things as you mentioned in the comment before taking it to repair shop.
But i could not even get to see the screen so bios menu is of-course out of syllabus.
por
@sbhatt9090
Happy you got it working at leastb cheaper than new laptop.
I am curious about what the repairer was referring to - the mainchipset perhaps.
por
@aactech yes jt was main chipset and only thing i think it mulfuctioned was due to lack of earthing in power supply.
por
Adicionar a sua resposta
shashank_bhatt1 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 94
Duração total: 10,666
