Ir para o conteúdo principal
Guias de reparo e manuais do usuário para o Lenovo IdeaPad 330-14AST. O Lenovo IdeaPad 330-14AST é um notebook projetado para uso casual.
Fix Mbr showing error
Imagem
As above question my problem is same
But it is showing this error
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Which version of Windows are you using?
Which error message did you get that prompted you to try and fix?
por Compartilhar
Adicionar um comentário
2 respostas
Pergunta mais útil
Type ''BOOTREC /FIXMBR ''and hit <Enter>.
This command will attempt to fix any corruption issues with the master boot record. If all goes well, you should see The operation completed successfully.
Next, type BOOTREC /FIXBOOT then hit <Enter>.
This command will attempt to write a new boot sector on the hard disk if Windows detects damage. Usually, this happens in cases where an older version of Windows was installed, or a non-compatible operating system such as Linux was installed.
If you are seeing an error such as Boot Manager is Missing, then the BOOTREC /RebuildBcd command might be able to fix it. This operation can also restore boot entries for older versions of Windows if you have a dual boot configuration.
If BOOTREC /RebuildBcd does not work, then Microsoft recommends you back up your BCD (Boot Configuration Data) store, then run the BOOTREC /RebuildBcd command again. Here is how you do it. Type each command then hit <Enter>:
·                     bcdedit /export C:\BCD_Backup
·                     c:
·                     cd boot
·                     attrib bcd -s -h -r
·                     ren c:\boot\bcd bcd.old
·                     bootrec /RebuildBcd
Esta resposta foi útil?
Pontuação 1
You sure it's not
fdisk /fixmbr
Pontuação 0
Adicionar a sua resposta
Satyam Singh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 70
Ao todo: 657
