How to fix fogged up lens?
The lens of my Huawei P20 Pro camera has water that is condensed on it. I can still take pictures but they are blurry. How do I fix it? Do I need to replace parts?
Esta é uma boa pergunta?
You do not need to replace parts, just take off the back panel and use a q-tip to clean all of the condensation on the inside part of the camera lens. If necessary, you can also q-tip the camera. Just always make sure to not put too much pressure. Hope this helps!
Step 4 on the teardown shows how to take off the back panel.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 947
