Ir para o conteúdo principal
O Motorola One 5G Ace é um tablefone Android lançado em 13 de janeiro de 2021.
Glass replacement...what should I know before trying.
Glass face only has shattered. What should I know before deciding on trying to fix it myself or have repaired.
Such as: how hard is it to open case and then close properly? Is there adhesive holding face-plate that will be compromised and so not go back together properly? Or anything to look out for when it is open and removing broken glass?
Esta é uma boa pergunta?
Pontuação 7
Adicionar um comentário
2 respostas
Pergunta mais útil
Too late for you but for the record: I had to get my Moto One 5G Ace screen fixed (just the glass, LCD was fine) and I took it to a repair shop. They fixed it, but apparently in the process they broke the speaker connection because of the way the adhesive was applied. Lucky for me they fixed it free because it was technically their fault, but it sounds like it might just be a matter of how the phone is constructed.
TL;DR be careful with the speaker cable when taking the phone apart to fix the screen.
Esta resposta foi útil?
Pontuação 5
2 comentários:
how much was the charge?
por
there is no speaker cable on either of the speakers. speakers are connected by spring contacts on the speaker itself and there's no adhesive used on them.
por
Screen replacement bord
Pontuação 0
1 comentário:
Made, we don't understand what you're saying or asking. Please state your question or answer in much more detail. That way even if this is a translation issue, we will still get a good idea of what you're saying.
por
Adicionar a sua resposta
LCuz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 4,539
