Ir para o conteúdo principal
O Asus Tuf Gaming FX505GT é um notebook de 15,6 polegadas com um processador Intel Core i5 9300H e uma GeForce GTX 1650. Ele possui o Windows 10 e foi fabricado pela Asus em 2018.
How can I fix the screen fitting issue?
So basically the mechanism from where the dislplay and laptop is connected , makes noise on opening and closing, and its also sort of loose so how can i open it and tighten it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hey Pratham,
Not a very clear question, but if I understand correctly you are having trouble with the area around the hinges. If that is the case you are going to want to tear it apart, generally by taking out the screws in the back of the laptop. Then use a spudger or old credit card to pry off the back. Not sure about this brand specifically, but you may then be able to pry up the front. You should be able to see by the hinges and get at your issue.
Hope this helps!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
PRATHAM SONI será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 305
