Ir para o conteúdo principal
The Samsung Chromebook 3, introduced in 2016, is the successor to the Chromebook 2 and features an Intel Celeron N3060 processor. The XE500C13-K01US model has 2 GB RAM while the XE500C13-K02US model has 4 GB RAM.
17 Perguntas Visualizar todos
Why is my chrome book display dark even though the blue light is on
I have a Samsung Chromebook 3 where the display is dark and the brightness is at max but very dark and you have to put a flashlight to the screen to see it please help! I tried moving the Chromebook to see if the connecter is loose sometimes it will work sometimes it won’t and I’ve tried charging it and moving the screen back and forth gently but still no dice.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
The led backlighting of your screen seems to be broken. You will need to replace the screen. Here is a helpful guide to replacing your screen Samsung Chromebook 3 Display Replacement
Esta resposta foi útil?
Pontuação 1
1 comentário:
thank you for this!
por
Adicionar a sua resposta
Manny será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 45
