Ir para o conteúdo principal
Samsung Chromebook 3 Display Replacement
O que você precisa
  1. Samsung Chromebook 3 Display Replacement, Bottom Case: passo 1, imagem 1 %32 Samsung Chromebook 3 Display Replacement, Bottom Case: passo 1, imagem 2 %32
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
    Pergunte ao FixBot
    Comentar
  2. Samsung Chromebook 3 Display Replacement: passo 2, imagem 1 %32 Samsung Chromebook 3 Display Replacement: passo 2, imagem 2 %32 Samsung Chromebook 3 Display Replacement: passo 2, imagem 3 %32
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
    Pergunte ao FixBot
    Comentar
  3. Samsung Chromebook 3 Display Replacement: passo 3, imagem 1 %32
    • Lift the case up and off the device
    Pergunte ao FixBot
    Comentar
  4. Samsung Chromebook 3 Display Replacement, Battery: passo 4, imagem 1 %32 Samsung Chromebook 3 Display Replacement, Battery: passo 4, imagem 2 %32
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Samsung Chromebook 3 Display Replacement: passo 5, imagem 1 %32 Samsung Chromebook 3 Display Replacement: passo 5, imagem 2 %32
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Samsung Chromebook 3 Display Replacement: passo 6, imagem 1 %32
    • Lift the battery up and out from the case.
    Pergunte ao FixBot
    Comentar
  7. Samsung Chromebook 3 Display Replacement, Display: passo 7, imagem 1 %32 Samsung Chromebook 3 Display Replacement, Display: passo 7, imagem 2 %32 Samsung Chromebook 3 Display Replacement, Display: passo 7, imagem 3 %32
    • Disengage the gold connector joining the display and motherboard by flipping up the hinge with a spudger and gently disconnecting it with a spudger or your fingers.
    Pergunte ao FixBot
    Comentar
  8. Samsung Chromebook 3 Display Replacement: passo 8, imagem 1 %32 Samsung Chromebook 3 Display Replacement: passo 8, imagem 2 %32 Samsung Chromebook 3 Display Replacement: passo 8, imagem 3 %32
    • Next disconnect the small coaxial cables from the wireless chip on the daughterboard by prying upwards with a spudger.
    Pergunte ao FixBot
    Comentar
  9. Samsung Chromebook 3 Display Replacement: passo 9, imagem 1 %32 Samsung Chromebook 3 Display Replacement: passo 9, imagem 2 %32
    • Flip up at least one side of the adhesive tape holding the coaxial cables in place. When the display is removed, the cables are coming with it!
    Pergunte ao FixBot
    Comentar
  10. Samsung Chromebook 3 Display Replacement: passo 10, imagem 1 %32 Samsung Chromebook 3 Display Replacement: passo 10, imagem 2 %32
    • Finally, remove the four 4.6mm screws from the display mounts using a Phillips #00 screwdriver.
    • It might be easier to open the laptop before removing these screws as the display will only come off while in the open position.
    Pergunte ao FixBot
    Comentar
  11. Samsung Chromebook 3 Display Replacement: passo 11, imagem 1 %32
    • Open the laptop and remove the display.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Austin Blakely
Membro desde: 03/11/19
23.035 Reputação
Autoria de 53 guias
3Comentários do guia
Any idea as to what kind of connector the display has to the motherboard? Or how many pins? Trying to tear down the display and see if I can use it as an extra monitor.
Sam Rall - Responder Compartilhar
It looks like there are 40 pins on the display connector. I’m not sure what it would be called or if it’s any kind of standard. If you do manage to convert the display to an extra monitor, you should definitely let us know though!
Austin Blakely - Responder Compartilhar
Great guide - my 12 year old son was able to get through it with a little help from me. Nice work.
smo2 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 49
Ao todo: 2,223
