Ir para o conteúdo principal
Informações de reparo para o Jeep Wrangler 2007-2018, a 3ª geração ou geração JK deste utilitário esportivo (SUV). Esta linha de veículos off-road inclui as edições Sport, Sahara, Rubicon e Unlimited.
tipm/ totaly intergrated power module
The TIPM’s on the vehicles have a high failure rate, they are expensive to replace and require an exchange, I belive its just some corrosion on the board and they are repairable. part# is 4692236ak and list price is $880.00
Update (07/07/2021)
I just want to see Ifixit Do a tear down and repair video on them.
Esta é uma boa pergunta?
Pontuação 0
6 comentários
Albert Anderson so what is your question? Yes they are expensive $1100 for my Jeep
por
So it depends on the failure. There are several issues with these. And I believe there is a bypass kit available that allows you to bypass certain failed issues. I know I purchased the bypass kit to have on hand for my Chrysler mini van. But I believe the jeep has similar issue. and will not start when certain things fail.
por
@gkjarhead do you recall what it is the kit? Maybe that gives us an indication of what fails.
por
@gkjarhead i see. They are bypassing the relays. Since it is a failure that seems to cascade makes me think there are issues with the traces. I guess we just have to see what we can find out. Thanks for sharing.
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Pergunta mais útil
Albert Anderson I don’t think iFixit is going to tear it down since those folks are just busy with all the other things they have to tear down. They really don’t have the people power to do so. You see, that is the beauty of Answers on here. Hopefully somebody has done it and post a guide soon or even better if you start tearing it down and be the first one to do so. You can then create a guide https://www.ifixit.com/Guide/new and post it for the rest of us. Now I do not have mine anymore since I had to return it to Jeep but maybe we can find a TIPM and work on it
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Albert Anderson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 31
Ao todo: 1,243
