Replacement cracked screen panel rca rtrq6522-us
Looking for replacement screen
65” rca rtrq6522-us
Esta é uma boa pergunta?
65” rca rtrq6522-us
AnytimeOutdoors GuideService you will have to do an online search for the panel. Remove the back cover on your TV and take a look at the back of the panel. You should find a label on there that tells you who build it and what model it is. Then do a search by that. That is the easy part.
The hard part will be to find one. Panels that size are usually not an easy find nor are they cheap if you do find them. Most replacement panels cost more (including shipping) then a new TV would. Of course check online auction sites as well as places like Craigslist and local pawn store and thrift shops. Every once in a while you can get lucky finding the same model TV that has issues other than the display. You can then harvest the screen from that. Remove the rest of the boards and sell those for repair might help recovering some of the cost.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 106
