Ir para o conteúdo principal
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1698 Perguntas Visualizar todos
It makes ice, dumps into the bucket but will not dispense.
Did anyone solve the issue… my LG makes ice just fine but when I put my cup on the door lever to drop the ice, no ice falls in my cup. No noise heard and no movement of the flap in the shoot. Water dispenses without issues….
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Hi,
What is the model number of the refrigerator?
por
There usually is a motor that turns a crusher arm or a dispensing rod. You said you do not hear anything. it might be that motor that is not working.
por
Adicionar um comentário
1 resposta
search for this “lg ice dispenser switch”
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
faby_812 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 23
