Ir para o conteúdo principal
The Samsung Intercept SPH-M910 is a midrange Android smartphone sold by Sprint, marketed as a newer, more affordable version of the popular Samsung Moment. Released in 2010 with Android 2.1 Eclair.
6 Perguntas Visualizar todos
How to replace the flex cable
i took my samsung intercept in to get repaired.they told me it was the flex cable that needed replaced and wanted to charge me 79.00.So now I am researching on how to do this myself.I have already ordered the flex cable.I now just need instructions on how to replace it
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
scott, check on here for the Incercept SPH-M910 disassembly. Hope this helps to get you started.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Same problem here, and the dis-assembly article does not go that far. Between step 8 and 9, there could be more detail showing how the LCD flex is mounted to the keyboard slider. The flex terminates on a board which is attached to the keyboard slider mechanism. This ebay listing http://www.ebay.com/itm/Flex-Cable-for-S... (or search ebay for m910 flex) shows the board. It is mounted with pins and adhesive and pops out.
por
Adicionar a sua resposta
scott será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 738
