Why did I lose all power and motor starts smoking and oil everywhere
Driving on freeway lose all power truck started smoking turn off I won't turn back on
Esta é uma boa pergunta?
@gordoloc we really do not have enough information to even come close to a definite answer. From the little info you are giving us it sounds like you have had a catastrophic failure with your engine. It appears it may have thrown a road or a piston. At this point you will have to start cleaning the oil slick off your engine and remove the shrouds etc. that cover the block. Take a look and see if there is damage to the black. Sometimes a rod can actually come out of the side of the block etc. Next remove the spark plugs and see if you can turn the engine. Use a socket wrench on your crankshaft pulley and see if you can turn the engine. Let us know exact year, model and engine size of your Ram
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 41
