My lower burner has quit heating.
Can this be repaired by replacing the heating fuse.?
Esta é uma boa pergunta?
Could be a fusible link. Could be the heating element itself. When I replace one I normally replace the other at the same time, if the equipment im working on has both. Check and see. You'll have to open it up. Disconnect both ends of the element and do a continuity check. If no continuity then it's a ad element
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 408
