My iPad pro 2018 12.9" lost backlight
Hi all, this is my first post. My iPad pro 2018 12.9 inch (model 1895) went black during usage outside at 28°C. Then I noticed that the actual display shows picture but the backlight is not illuminating any more. I have opened the iPad and checked the logic board for visual damage but everything seems to be OK. The filters next to the display connectors are also ok. Does someone has experienced this issue or has the schematic for my ipad? Would be very helpful
Esta é uma boa pergunta?
How did you test the filters
por daniel
I have used this video as a guide: https://youtu.be/6FnO1oY-voM
It is not the same model but has a similarly design at some circuits.
I did not had any burned filters but found a burned cap (optical burned but not shorted).
por Serdar Yagcioglu
Do you have a multimeter
por daniel
Yes. Do you have schematics available for this model which is showing where the backlight circuit is located?
