Ir para o conteúdo principal
Informações de reparo e desmontagem para o smartphone Android topo de linha S20+ da Samsung, lançado em março de 2020.
No network after screen replacement
Replaced the screen/frame on an AT&T S20 Plus, transferred over all parts including front camera, charging daughterboard, 5G antennas, etc. After sealing it back up, it’s not detecting the cellular network. Fearing a bad part, I put it back in the original screen/frame and same thing. All connectors look fine, pressure pins on the charging port are in good condition, too. Anyone have any ideas? Thanks in advance!
Esta é uma boa pergunta?
Pontuação 9
2 comentários
I have the same problem with my s20plus after replacing the screen no network signal. And I do not see any network cable on the main board or on the screen to transfer how to resolve it please???
por Compartilhar
Why this issue happened
por Compartilhar
Adicionar um comentário
5 respostas
Pergunta mais útil
Imagem
Imagem
I know on a S21 Ultra, I did a screen assembly swap and the part was identical but once I powered it up I had the same issue. Not a single answer made sense. Finally someone mentioned replacing the screen assembly fixed there’s. I dug deep into the screen assembly and learned there is a small antenna flex on the corner and it’s held down by tri-wing screws. It turns out they aren’t universal. The “international” assembly uses a different band antenna. So I swapped my original flex and instantly had a signal again but this time it actually worked on the AT&T network. What an ordeal! Maybe the S20 is similar? As it turned out, the SM-G998U uses a different version of this LTE/4G antenna than the screen used on the “B” variant (SM-G998B)
Esta resposta foi útil?
Pontuação 7
8 comentários:
We found the same thing and it seems swapping the flex works sometimes. It'd be easier if suppliers were a little more open about their "U" model service packs actually being "F" models.
por Compartilhar
Yep same thing! Took me hours to narrow it down
por Compartilhar
Can you tell me where this Flex antenna is located? I just swapped all the internals of my Canadian s20 plus to a replacement screen frame and I'm having the same issue. Thank you
por Compartilhar
Looking into the old frame, should be upper right side, runs against the inside. There are about 4-5 torx screws and some adhesive holding the connector down. The new frame may will have a very similar part except it will have a slightly different “type” printed on the connector. Like NA or int. It may not even have one. Just carefully transfer the one from old frame to new one.
por Compartilhar
I think I know where you're talking about. I think that's where the 5g antenna is. My Canadian s20plus doesnt have that antenna on the mid frame. It's just a empty slot on the old frame
por Compartilhar
Exibir mais 3 comentários
It’s not the 5g slot with 2-Philips screws… it’s pushed up into the frame. I used to have a picture. “Flex” it’s a ribbon with 4-5 attached hold down screw slots it’s L shaped to fit in upper top and right side.
Pontuação 0
Be careful of the replacement screen assembly. Example: if you have a US Model on Verizon, the replacement will not be compatible if it’s an “international” model. And vice versa. The LTE/4G antenna boards are also different bands.
SM-G985F Would be incompatible with SM-G985U similar with 986’s. This may sound confusing and frustrating.
I hope this bit of feedback helps you.
Pontuação 0
First of all I need to check your network flex it can be issue or something if u you not getting network or issue because some thing with screen damage it can be damage so I need to check it
Pontuação 0
Any solution?
Pontuação 0
Adicionar a sua resposta
Brann Kelley será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 68
Ao todo: 15,512
