Ir para o conteúdo principal
Quarta geração da popular linha de sedãs e cupês da Série 3 da BMW.
No ignition when trying to start
My bmw won’t turn over it shows a sign of a car on lift and also of a coolant type picture I have an icarsoft obd2 but it does not clear the codes my car has been stuck for over a month I need help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
if there’s lights on the dash indicating an issue then get a diagnostic tool plugged in, lots of BMW’s once these lights are on won’t allow you to start the car for safety reasons probably to protect the engine. BMW specialist or a in depth diagnostic tool to read it before taking any guesses rather than a standard OBD tool, The light comes on for a reason, clearing it won’t do anything other than just come back on and cause more damage more than likely continuing to drive it. the icon with the car on a lift is an indication built in to the car meaning it is due for a service, if it hasn’t been done recently may explain why the coolant light is on too.
Esta resposta foi útil?
Pontuação 1
Esta resposta foi dada inicialmente para uma outra pergunta.
you have not done a thorough analysis or have not communicated all that you did.
For starters, “not turning over” would indicate the engine isn’t moving as opposed to “not starting” which would indicate the engine is trying to start by ”turning over”.
If it is not turning over then you must listen to see if you hear the starter solenoid working and pulling in the gear to the flywheel. If you don’t hear that, then a battery test is in order. If that is good, then you must determine what is wrong with the solenoid == wire, connection, solenoid, or ignition key or circuit.
If it is pulling in and the starter isn’t running, then either, the starter relay which is part of the solenoid/starter assy,, the starter itself or the engine is frozen up. A frozen engine would be indicated by severe dimming of lights when the starter engaged since it draws significant current when locked.
HOWEVER, with the dash indicator you are getting, you may have a coolant sensor that prevents the car from turning over if the water is low or the sensor is bad. You will have to research that.
I would recommend doing a little more analysis and searching for a BMW forum to ask the question.
Pontuação 0
Adicionar a sua resposta
Michael Tetu será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 440
