Ir para o conteúdo principal
External storage options by Seagate, usually connected by USB, available in many storage sizes and form factors.
Can’t find screw bit for External HD
Can’t figure out the screw bit needed for this and that’s after going through my bits in my pro tech tool kit.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
That looks like a Torx TR6, TR8 or TR10 screw. There are two versions of Torx these with a pin in the middle is the security version (TR)
By chance is this a five lobe screw? Your image is not very clear, then that would be a 5-Point Tamper Resistant Star Bit
Imagem de Compatible with both T8 and T8 Security fasteners (TR8). Precision fixed blade screwdriver engineered by iFixit.
Produto
TR8 Torx Security Screwdriver
$5.99
Imagem de Compatible with both T10 and T10 Security fasteners (TR10). Swivel top handle with precision tip driver.
Produto
TR10 Torx Security Screwdriver
$5.99
Imagem de Precision fixed blade screwdriver engineered by iFixit.
Produto
TR6 Torx Security Screwdriver
$5.99
Esta resposta foi útil?
Pontuação 3
1 comentário:
Typical T6 or T8 security Torx screw.
por
Hi @danj ,
Here’s a better view of it to confirm
Click on image to make it even bigger ;-)
Cheers
Pontuação 3
6 comentários:
@jayeff - Ha! You've got younger eye's ;-}
por
So since that’s a five ‘star’ what’s the exact bit name I would need?
por
@gingersenpai
See the link regarding the 5 point tamper resistant star bit in the above answer
por
Hi @danj,
Don't know about that. I'm pushing 70 this year ;-)
Cheers
por
Exibir mais 1 comentário
Adicionar a sua resposta
Scott Vogel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Ao todo: 130
