Ir para o conteúdo principal
O controle do Xbox One foi introduzido em 2016 com o lançamento do Xbox One S e adiciona suporte a Bluetooth para Windows 10/11. Este controle corrige muitas das falhas de design encontradas nos modelos 1537/1697 e é muito mais confiável. Este controle foi substituído pelo modelo 1914, que é aprimorado.
Controller buttons not working
When I play certain games such as the sims 4, the left thumb stick constantly moves but in other games is fine . Also whilst playing the sims the d pad doesn't work at all? But in other games is perfectly fine?
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
connecting to a computer? or on the xbox console?
por
Connecting to my xbox 1
por
Adicionar um comentário
1 resposta
The fact that it only happens in Sims 4, and the D-pad works in other games, is a big clue — a broken D-pad usually fails everywhere, not in one game. So first check Sims 4 itself: reset its controls to default, turn off any mods or custom control schemes, and check whether the game is using a different controller profile or has camera controls mapped to the stick.
Also, with the controller on a table and untouched, watch whether the left stick creeps on its own in other games. If it only creeps in Sims 4, that again points to that game's settings.
To check whether the controller itself is sending those inputs,test your controller online for free and press each D-pad direction and move the left stick slowly. If every press registers cleanly there, the hardware is sending the right signals and the fault is almost certainly in Sims 4's settings, mods, or profile. If a direction misses or the stick drifts untouched, clean around the stick, check for a stuck button, and test wired versus Bluetooth before opening it.
Disclosure: I run this free tester.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
[deleted] será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 6
Últimos 30 dias: 9
Ao todo: 204
