Ir para o conteúdo principal
Installed RRoD repair kit, now I have video problems with HD component
I installed RRoD kit, reflowed motherboard and repair seems to have worked but....when I hooked the Xbox up with component cables there is a vertical line down center of screen with a double display. Unit works with Standard definition cables and also with PC cable. Is this a problem with the cables or did I damage the graphics card?
Dave
Esta é uma boa pergunta?
Pontuação -1
1 comentário
What exactly do you mean by double display?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
It sounds to me like that would be a case of bad cables. Do you have a friend that has the hd cables? If you do and you know they work on his console this would be a good way to test for the real problem.
Hope this helped,
Cody
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
daveboulanger será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 606
