Ir para o conteúdo principal
Samsung's flagship phone-with-stylus and the successor to the Note8, released August 2018. Features a 6.4" display and up to 512 GB of onboard storage.
104 Perguntas Visualizar todos
Cellular Antenna Issues Galaxy Note 9
I dropped my Samsung Galaxy Note 9 last October, cracking the screen and display assembly. I replaced the display assembly myself (and replaced the charging port), but ever since have been getting a weaker than normal cell signal. It is typically one or two bars less than my brothers device at any given location. This issue leads to dropped/ unstable calls, failure to send texts, etc. GPS antenna also seams to go offline more frequently. I’ve tried all the software fixes, and am convinced it is hardware related. Where are the antenna locations on the phone? Are they replaceable or modifiable?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
I would replace the charge port and the small coaxial antennas that attach to the charge port. Just make sure you order the right variants according to your model number. I’ve seen customers and other repair shops replace their ports with the wrong variant resulting in cellular issues although the most common symptom was it would say “No SIM”.
Esta resposta foi útil?
Pontuação 1
For modern phones, the antennas could be all over the edges of the phone, and multiple antennas are required to ensure proper cellular reception and throughput, so if you have to fix them, fix all of them.
Pontuação 1
Adicionar a sua resposta
Evan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 19
Duração total: 1,244
