Ir para o conteúdo principal
A portable Bluetooth speaker manufactured by Ultimate Ears.
UE MEGABOOM only working when plugged in
Had my speaker for over 2 years now but the charging light stopped working suddenly. The speaker is now stuck at 40% charge and stops working as soon as the charging cable is pulled out.
When I took out the battery and then plugged in the light started blinking but when I inserted the battery again it's still the same outcome.
I have read all the previous questions posted here about this issue and none have a solution. Can I play my speaker like this only plugged in?
Is it bad for the speaker to run on only the wall electricity? as the battery or current going to battery is not working.
Update (06/02/2021)
Any help would be appreciated please guys
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi,
Try replacing the battery and check if that resolves the problem. Even rechargeable batteries have a lifespan
here’s the Ifixit Logitech UE MegaBoom Battery Replacement guide that will help.
Replacement batteries are available online. Just search for CS-LOE116XL to get results.
Esta resposta foi útil?
Pontuação 1
It sounds like the charging port is bad or it has some sort of water damage.
Pontuação 0
1 comentário:
I'm sure there is no water damage. Is there any way to fix the connection between the battery and the usb charger?
por
Adicionar a sua resposta
Animesh 7 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 18
Ao todo: 821
