Ir para o conteúdo principal
Repair and disassembly information for the first generation of Apple's high-end wireless earbuds. Released in October 2019. Identified by model numbers A2084 (left earbud), A2083 (right earbud), and A2190 (charging case).
67 Perguntas Visualizar todos
got a replacement airpod, went downhill
my brother had 2 sets of airpod pros and i lost mine, so he let me have one of his. it only had one airpod though, i didn’t care but i did ask for a replacement airpod. my mom ordered it. before i got it, the case worked and the one airpod inside worked. one thing i also want to know is i could only connect it when the case was on the charger. i thought that was odd. when i got the replacement airpod, nothing worked anymore. the case will only show the green light when the airpods aren’t in th case, nothing will connect nor turn on. how do i fix this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I had a similar problem, I got a replacement and it wouldnt connect. I just reset the airpods case and followed a guide from apple on how to pair a new airpod to your case, and just let them sit charging in the case for a while and that fixed it
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
mina yo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 109
