Ir para o conteúdo principal
O Gateway FX6840 é um computador de mesa que possui um processador Intel Core i7.
How to repair RAM at home?
Hi Ifixit Support Team, I am new here, I am a user of Gateway Laptop. My laptop ram is faulted and my laptop is going to an on/off situation many times. Kindly Ifixit Support Team, tell me how to remove the fault of the laptop easily.
Esta é uma boa pergunta?
Pontuação -1
1 comentário:
need the laptop model to properly help you
por
Adicionar um comentário
1 resposta
Hey George,
I have got to say using a Gateway may not be your best choice, but I digress.
Are you getting a BSOD?
You can try opening and removing the RAM and re-installing it, making sure to have a good fit. Or replace the RAM if that is an option.
I know this isn’t RAM related but you could run a CHKDSK from the run dialog box and check your hard drive.
There could be a potential for a failing power supply as well, or a virus.
Without more information it is really hard to say., but those are a few things to try.
Hope this helps.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
George Bell será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Ao todo: 321
