slide lock will not unlock
my iPod2 is damaged and the right corner screen broken and the back dented slightly on the right corner..I have reset and restored but cannot get the slide lock to unlock..
Esta é uma boa pergunta?
You probably need a new screen. Depending upon where the dent is, you may have damaged the component the digitizer plugs into. In that case the repair becomes out of reach for most but can be done by replacing the motherboard flex cable.
In your case spend $15 on a new screen and start there.
Good luck
Esta resposta foi útil?
It is possible the connector just popped out... check that before ordering a new digitizer.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 927
2 comentários
iPod2 meaning iPod Touch 2nd Gen?
por oldturkey03
yes sorry I wasn't specific..
por kelly
