Ir para o conteúdo principal
Guias de reparo e suporte para a terceira geração das picapes C/K.
Cylinder 1 backfire through intake
78 gm 350 5.7 Cid. 4 bolt main Backfire through intake/carberator.
Rods are good, even compression
New distributor, timing gears/chains, plugs, wires, fuel lines, fuel filter, new edlebrock 650cfm carb, lifter springs don't appear to have any wear (push test). When I disconnect cylinder 1 plug from distributor, I know longer have back fire.
My thoughts are a potential whiped cam lobe on cylinder 1 or a single bad lifter. Lookin for help!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Before opening the engine, check the fuel injection needles inside the carburetor, I have the same problem. One of the needles is loose and is injecting more.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kenneth Sapp será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 138
