Ir para o conteúdo principal
This receiver is Bluetooth Ready, has 110 Watts x 5 Direct Energy Amplification and is iPad / iPhone Certified with supplied cable
26 Perguntas Visualizar todos
Receiver was working then won’t turn back on.
I was playing music off my phone. It was working fine then it all of a sudden turned off and won’t turn back on. Where should I look to find the problem and what could the problem be?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @edgargallardo25 ,
Have you checked that the power outlet that the receiver is connected to is working, you didn’t say?
If the outlet is OK then here’s the no power troubleshooting flowchart from the service manual.
This will be a good place to start looking for the problem.
No power problems are not always the same. You have to start testing the power circuits to find out what and where the problem is
Esta resposta foi útil?
Pontuação 1
1 comentário:
The power outlet works fine, I made sure to test it and used another receiver there after I unplugged the pioneer. Thank you for the service manual. I will be checking that out.
por
Adicionar a sua resposta
Edgar Gallardo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 136
