Ir para o conteúdo principal
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
20 Perguntas Visualizar todos
What is the capacity of my Kenmore Elite Oasis?
Model #110.28032701?
This is the larger model (King Size Capacity Plus) not the regular size one. Looking for the Cubic Feet Capacity and can’t find it at all in the owner’s manual.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @dribnus ,
If no one comes up with a precise answer a quick way to do this is like finding the volume or cubic capacity of a cylinder, where the washer tub is the cylinder.
Calculating the Volume of a Cylinder
1. Measure the width of the tub and divide by 2 to get the radius.
2. Calculate the area of the tub:
To do this, just use the formula for finding the area of a circle, A = 3.14 x r x r (where r is the radius)
3. Measure the depth of the tub
4. Multiply the area by the depth.
Use the same measurement base e.g. feet for both the radius measurement and the depth measurement.
The answer will be in cubic feet.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks, I was actually just thinking of doing that.
por
OK, I just did that. I measured from the bottom to the top of the metal tub and no higher as that's the plastic part "above " the tub.
Then the diameter is a bit tricky to get at the same height and not letting the agitator spindel get in the way. But, got that. Ehhh shades of Trig etc... So, it was fairly close to the 4.6 which I thought it may have been. Assuming I measured from the right area. So, thanks for "pusing me" to use math LOL.
Thanks!
por
Adicionar a sua resposta
Carla Pappalardo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 59
Ao todo: 2,790
