Ir para o conteúdo principal
This 20" Dell All In One can be identified by the label on the back along the bottom of the display.
11 Perguntas Visualizar todos
How much ram is enough?
I have a Dell Inspiron one2305, about to upgrade to an SSD and was wondering if I should upgrade ram to. Has 6G of DDR3 ram right now. Only used for average home computing. Is just a bit slow. If so How much and what type?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi,
According to this link 8GB (2 x 4GB DDR3L- 1600 UDIMM) is the maximum amount that the computer supports.
Most Win 10 PCs work reasonably well with 8GB of memory but not if you’re into gaming.
Here’s the service manual for the computer. Click on the memory module(s) link at the start of the manual, to view the necessary pre-requisite steps and then the procedure to replace the memory modules.
Since you have 6GB already I assume that it is 1 x 2GB + 1 x 4GB so if you only replace the 2GB with a 4GB make sure that both the 4GB modules will have the same specifications. You should be able to find them on the module itself
Esta resposta foi útil?
Pontuação 1
6GB is plenty just for getting on the internet.
Pontuação 0
Adicionar a sua resposta
arlandjcook será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 21
Duração total: 302
