Ir para o conteúdo principal
Ventilador torre Holmes usado para resfriar ambientes internos.
How to put this back together again?
I bought this at a rummage sale for $8 and I was trying to take the front part off to clean it out and the base fell out. What happened was all of these parts fell out and I have tried to put it together several times. Can someone walk me through and show me how to put this together again or this is food for the trash can? It came with no instruction manual and I looked up the manual on the internet and it shows me nothing on how to put this back together again. It’s a Holmes Oscillating Tower Fan 32 Inch with Remote Control, HT38R-U. I have included pictures. Thank you.
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
this might be more problem than its worth.
good on you for trying to fix it though!
it looks like in the pictures you have some ball bearings in your hand. unless you have the cover for the bearing you wont be able to keep those roller balls in the bearing. eventually the bearing will wear out and will not do its job.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mary Goldsmith será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 1,032
