Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
794 Perguntas Visualizar todos
Slot de memória em curto
Hi, My name is Carlos. I’m from Brazil
I have a Mid 2010 13” MacBook Pro A1278. Memory Slot 0 (next to the motherboard), must be in trouble. When I put a SO-DIMM stick in it, the equipment turns on and does not upload video. When I put the SO-DIMM in slot 1 everything is normal.
How to replace the defective slot?
I will be grateful for someone to send a step by step.
Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Sadly if the memory slot is bad there is little you can do other than replacing the logic board.
Let’s give this a try first! Carefully loosen one quarter turn the four screws which hold the memory socket frame.
Make sure you are using the correct SO-DIMM RAM - 204-pin PC3-8500 (1066 MHz) DDR3 SO-DIMM
And keep in mind this system is limited to 8GB using two 4GB SO-DIMM’s
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
universidadedelphi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 7
Duração total: 25
