Ir para o conteúdo principal
Released in March 2017, the Moto G5 Plus (model numbers XT1687, XT1680, XT1684, XT1685) includes a 12.0 megapixel rear camera, a 5.2 inch screen with a 1920 x 1080 resolution, and the Android 7.0 (Nougat) operating system.
Why does screen stay black when calls come in?
I am the original and sole owner of a Motorola G5 plus 64gb running Android 8 1. After my first year of ownership (approximately) I started to notice that my screen would stay black when I was receiving an incoming call. Nothing I tried could wake the screen: I tried pressing the power button on side and also touching the thumb pad /finger print sensor but nothing worked. But after I missed the call the screen would wake to tell me so (ie that I missed a call…thanks a lot). Here's the even more bizarre thing…it only happens about 50% of the time (approx.). It's really frustrating because I have to wait till I miss the call to find out who was calling me so I could then call them back.
Help!
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Solução escolhida
it has to do with the proximity sensor, usually when you have flip to mute enabled in the my moto menu/app it shuts off the display in order to save power and mutes the incoming call.
this can occur if the adhesive around the proximity sensor loosen and form a gap between it and the glass or ge debris or residue get on the inside or outside of the glass.
the solution i have found, although a bit barbaric is to apply pressure AROUND the proximity sensor and whilst doing so taking the call.
if this doesn’t help wiring a headset and taking the call with the remote is an option
Esta resposta foi útil?
Pontuação 3
1 comentário:
the earphone trick works
por
Hi,
Strange that it only occurs 50% of the time.
Try the following to see if it resolves the problem or at least narrows down the cause of the problem further.
Being intermittent you may have to leave it for a while after doing each of these procedures until you know one way or the other whether it still happens.
Wipe the cache partition and then check if the problem still occurs.
If still occurring, start the phone in safe mode and check if the problem still occurs.
if it doesn’t happen when in safe mode, then a downloaded app is the cause of the problem. You will have to uninstall each downloaded app, one at a time and check the phone in normal mode between each uninstall, to see if the problem is still there or not. When the problem no longer exists then the last downloaded app that was uninstalled is the culprit. A downloaded app is one that you downloaded and installed and wasn’t pre-installed on the phone when you first got it.
Pontuação 1
6 comentários:
Jayeff, my thanks for the suggestions. I’ll give this a try over the weekend (I’m in the middle of a very busy week) and will report back over the next week to give you appropriate and, more importantly, accurate feedback. Thanks again. Mark
por
I have the same problem screen goes black on incoming calls and you can't pick up the call
por
Same with me. And it is only 50% of the time also.
por
Yes this happens to me when phone in my pocket and take out to answer always have to person back
por
Same problem with my phone. I looked at the two responses to deal with this but unfortunately I don't know where the proximity sensor is or how to wipe the cache partition.
por
Exibir mais 1 comentário
Throw the phone in the garbage, problem solved.
Pontuação 0
1 comentário:
Update:I have since replaced my phone with a newer, more powerful model from Samsung (A54) which is running the latest updated version of Andoid 16 along with Samsung's 8.0 version of their One UI interface. Even with this newer more powerful msung model, I still experience the same issue where the phone's screen will suddenly go blank during a call and I am unable to subsequently get the screen back up again. My friend also has this same intermittent problem on her Samsung S phone. I have tried to check for adjustments to the proximity sensor as another responder previously suggested but I have not been able to find such a setting. What I did find was a setting which is supposed to keep the screen on while one is looking at it - but even that functions correctly only some of the time. Is it the phone? Is it Android? Unfortunately, I still can't say I know for sure why these issues occur. It sure would be great if the technology worked like it's supposed to.
por
Adicionar a sua resposta
Mark DiRollo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 31
Últimos 30 dias: 140
Ao todo: 19,593
