Ir para o conteúdo principal
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 Perguntas Visualizar todos
Pergunta encerrada
digitizer n ot working after replacement
Hello everyone, i got into my hands a ipad 4th generation from another shop that came in for digitizer replacement that stop working after a new one was installed i asked the tech if he used metallic tweezers or screw driver to disconnect the cables from the connector, he said yes so i would know where to start looking since he already check connectors and tried other new digitizers.
im new in micro soldering and i like to get deep into board level repair and most (80%) i find the problem (hopping to get better 95% at least)
i found out the following: not voltage in U3101, R3107, R3120
i followed the voltage supply to the following chips and replaced them but no luck: U300, U3007, U3009, U3010 and the digitizer driver IC U3101
all of those ICs have not voltage, if someone can help me find the problem i will appreciate it, thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Is there any components knocked off the logic board.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 17
