Ir para o conteúdo principal
Guias de reparo e informações de resolução de problemas para o Game & Watch, uma série de 60 videogames portáteis produzidos pela Nintendo de 1980 a 1991.
Right button moves character left
I have an OCTOPUS Game & Watch that works fine except that lately, if I press LEFT once during the game, LEFT stops working and if I press RIGHT the character moves left for about 5-10 seconds and after RIGHT moves the character right again, the problem repeats itself. I did try to do a light cleaning with rubbing alcohol and although the buttons are more responsive, the problem didn’t go away. Has anyone else experienced this or know how to fix it?
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Did you also give the motherboard a light clean with the alchhol?
por
Adicionar um comentário
1 resposta
Im having a similar issue, except my left button doesnt work and the right button is spammed upon powering the g&w… i have parachute, so maybe theyre kickin the bucket after 40 years. :/
Esta resposta foi útil?
Pontuação 0
2 comentários:
Fixed it! Mine had residue from the carbon pads on the membranes. I just scrubbed contacts with some isopropyl with a qtip as a last ditch effort after checking all the test points with a multimeter. What i thought wouldve been corrosion, really turned out to be carbon and rubber gummed up. It looked clean, but turns out it was dirty. Good luck brotha
por
IPA only on the board and button pads - NOT ON THE RIBBON CABLE.
ruined a donkey kong 2 erasing the connectivity pads of the black and white OG ribbon cable.
new ribbon cable on fleabay £20 macguy/canada - verified working replacement. gold coloured modern looking.
por
Adicionar a sua resposta
GameNWatch será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 777
