late 2012 iMac display lvds cable replacement
hello,
in preparation to service my imac late 2012 i know one needs to carefully disconnect LVDS cable tape module from the mobo while in the process of opening.
Could someone instruct how to disconnect LVDS from the display panel side in case I’d damage the cable and need to remove damaged cable from the panel? does it tab out same as the mobo side?
Also if possible if there are visible marks to note which way is correct “up” while connecting new LVDS ?
Esta é uma boa pergunta?
