Schlage FE595 latchbolt stuck
This Keypad Lever with Flex Lock has served well for several years. But the latch bolt, for no obvious reason, no longer retracts on the strike plate when we close the door unless we move the lever. It doesn’t matter if the Flex Lock is locked or unlocked. The outside operation - lock, unlock states - is normal. The door closer can no longer close the door without operating the lever, which renders the ADA door closer function useless. The door, hinges, lock, and door closer work perfectly and the batteries are fresh. Just the latch bolt stops the door from latching by itself when the door closes.
Product page = schlage.com/en/home/products/FE595PLYFFFFLA
Any help would be appreciated!
Esta é uma boa pergunta?
