Ir para o conteúdo principal
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
Replacement battery not recognized, not OEM specs
On battery install, warning about not recognizing battery. I turned off notification in BIOS. It registered 60%, I drained for calibration, now won't work without adapter plugged in and reads battery as 0%. Shuts down when adapter unplugged.
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
where did you get the battery from? I wonder if Dell serialized the battery, essentially tying it to that specific machine...
por
I got mine from I fix it and same problem. Warning message on startup that it is not a Dell battery and it refuses to charge it ?
por
Adicionar um comentário
1 resposta
Dell has stopped supplying these batteries, and my bios tells me the battery is not recognized. I purchased from IFIXIT
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Reggie Stecher será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 374
