Ir para o conteúdo principal
O ASUS Transformer Book Flip TP500LA é um notebook 2 em 1 com uma tela de 15,6 polegadas e display de 360 graus.
How to replace Touch Screen Digitizer on ASUS TP500LA?
I need to replace ASUSTP500LA LAPTOP TOUCH SCREEN, I removed the broken one, but I do not know how to connect the new one.
Update (03/24/2021)
I am so sorry, I forgot to add the images
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
This web site somewhat shows how to install the new Touch Screen Digitizer:
https://www.laptopscreen.com/English/mod...
Esta resposta foi útil?
Pontuação 1
2 comentários:
The information is not the same to the laptop I have. I removed the broken
screen, I can not put back in the frame the two connectors
por
@vmarquez079
Hi Victor,
Are you certain you have correct part? Look on the broken one for its part number and on the replacement part to see if you have the correct one.
Installing should just be the reverse of taking out th broken part.
The web page I sent you should give you some hints on what to do.
Did you click on the info tabs for more details?
por
Adicionar a sua resposta
Victor Marquez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 22
Ao todo: 339
