Ir para o conteúdo principal
Smartphone da marca chinesa, utiliza o AndroidOne, parafusos Pentalobe frontais
New LCD no brightness
I changed the LCD of the phone, using a 3rd part LCD, everything works fine until it turns on. Once it starts to turn on the brightness goes very low and I can’t see anything, I tried to raise the brightness level but nothing changes. I made a video that I think explains better my problem
https://www.youtube.com/watch?v=W_n96rVc...
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
The backlight is not working. Try reseating the connector, and if that does not work, the third-party display may be the culprit. Try another replacement display in that instance, and the dealer of your old unit should refund you for the faulty part.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ionut Robert Cojocaru será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 35
Ao todo: 860
