Ir para o conteúdo principal
O smartwatch quadrado de plástico da Amazfit, empresa do grupo Xiaomi. Lançado em 2017.
Battery replacement on Bip
Does aynone tried to replace the batteriy in the watch? It seems my watch battery capacity reduced. Last depleeting cicle took only 15day but usualy it took 30-45day to drop to 15%. What kind of battery can be used to replace the original?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
5 respostas
Pergunta mais útil
Replacement Bip battery
https://www.ebay.co.uk/itm/204240393865?...
Esta resposta foi útil?
Pontuação 1
Hi there! The battery used on the Bip (model A1608) is a 200 mAh lithium ion battery. I’ve also been having issues with my Amazfit smartwatch regarding battery charge depletion. I think it may be something to do with your plug adapter or the fact you may have left it on the charger a bit too long after it reached maximum charging capacity.
Pontuação 0
1 comentário:
I think it's the BMS. Mine drains in 5 minutes but you can still turn it on with long press. Then recharge for minute and it says 90% again.
por
I suspect this is some software update result not really the battery. I already bought a bips and that have even shorter battery (tooks about 9day to depleet). So the old bip sits in its onw box. After about 6mo I checked what is the battery status and put on charger it was about 85%. If the battery would bad I suspect it would not even turned on.
Pontuação 0
wher can i get amazfit bip u pro battery.???
Pontuação 0
Battery replacement
Pontuação 0
Adicionar a sua resposta
Dimitryj Tyer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 75
Ao todo: 4,920
