Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
774 Perguntas Visualizar todos
How to remove a MacBook cover screw that is broken without any tools
I have a macbook pro 15 inch 2015, when I tried to remove the case I notice that the bottom two screws near the trackpad won’t turn. When I take in for a closer look the screw seems to have been stripped or broken to the point that Icant remove it with a pentalobe screwdriver. I’ve tried using superglue, rubberband and even latex gloves, but it won’t work. I am planning to replace my battery. Should I use a drill to drill the screw and replace it with a brand new screw?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
you might try taking a drill bit with your hands to see if it will grab the screw enough to loosen it.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I will try it thanks for the advice
por
Adicionar a sua resposta
Anthony Wijaya será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 76
