Ir para o conteúdo principal
The fourth-generation Surface Pro tablet, released October 26th, 2015.
208 Perguntas Visualizar todos
Will I need to replace the screen adhesive after a battery fix?
This is one of my first replacements, and I’d like to know if my Surface Pro 4 will function as intended after a battery replacement without adding new adhesive.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It will function, but you need some adhesive to secure the screen to the chassis. Not only to keep it in place, but the Surface tablets are a bit sensitive to ‘ghost touching’. Securely mounting the screen helps here. You can use thin general purpose double adhesive tape (3M black for example), it comes in various sizes. Clean first!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Joshua será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 56
