Ir para o conteúdo principal
Released in 2018, the Lenovo IdeaPad 330 is part of the IdeaPad 300 series, a class of home and office PCs.
7 Perguntas Visualizar todos
Screen replacement upgrade or trade in?
With my lenovo 330 ideapad model 81de would it be possible to upgrade with lenovo parts to a 1080hd resolution instead of 768? It's a great clunky laptop I enjoy. I want to also upgrade my ssd to 2tb instead of the 500gb ssd I put in it. I also want to put a 16gb 2133 ddr4 sodimm for a total of 20gb ram. Currently there is a 4gb 2133 ddr4 sodimm soldered to board and a 3200 8gb sodimm in the changeable slot. But if the screen display is not upgradable with some work then I will trade in sometime and save the upgrades for next laptop
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Looking at the parts list for your model, it seems that FHD LCD panels i.e. 1920 x 1080 are compatible. Click on Select Commodity > LCD panels (8) to find the Lenovo part number. Searching online using the part number only will get results for suppliers of the part.
Here’s the hardware maintenance manual for the laptop that will help with doing any hardware changes/upgrades etc.
According to this supplier a 2TB SSD will work but it needs to have a 7.0mm to 9.5mm adapter to ensure that it is positioned correctly in the drive bay to make a solid connection with the sata port connector
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you I learned something new about manuals thank you for quick reply
por
Adicionar a sua resposta
The Prince será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 246
