Ir para o conteúdo principal
Informações de reparo e resolução de problemas para as TVs UHD da Samsung de 50, 55 ou 60 polegadas com o número de modelo JU6800, lançadas em 2016.
Top half of screen is dark
Top half of the screen keeps going dark, and have little bright shadow on the screen
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi Mark, I have a Samsung UE50JU6800 that has just developed the same issue.
Imagem
Whilst i dont have a definitive answer yet, i found a video from Shivamm Rane on youtube ( a search on Youtube will find it, unsure of iFixits rules on links ) that details replacing either the entire LED light strips or individual LEDs on Samsung TV’s that cause this issue. It will be a few weeks before i attempt my repair but hope this helps you on your way.
The replacement LED strips seems quite readily available on Ebay.
If i am successful in my repair will post a guide.
Esta resposta foi útil?
Pontuação 0
3 comentários:
Was the repair successful?
por
U mnie jest na odwrót na dole jest ciemniejszy ekran
por
@szmondjabin in that case your bottom backlight strip has failed. Replacing it should fix that.
@szmondjabin w takim przypadku uszkodzony jest dolny pasek podświetlenia. Wymiana powinna rozwiązać problem.
por
Adicionar a sua resposta
Mark Broadbent será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 28
Ao todo: 1,172
