Charging IC (is625Hrtz) of my 13" MacBook Pro burnt
Hello,
The charging IC is6259HZ is burnt badly. Further the pins from 15 to 21 of is6259HZ & R7001 & C7050 are also damaged. The battery was not getting charged with this. However, the green light is coming on the connector of Magsafe adapter.
Further I have tried the other charged battery from my friend’s system in my system and it is working all fine. The computer is running all okay I guess with charged battery. Kindly suggest in detail (I can solder a few things):
- Is there any way to charge the battery externally using supply (via shorting any circuit etc.) ?
- Or, I could turn on the system with any power supply via battery ports?
Esta é uma boa pergunta?
6 comentários
Battery type is A1322
por vivek
What is your motherboard number (820-XXXX)?
por honakrisi
it is 820-2936
por vivek
I tried to inject 12v,3amp supply in 3rd(GRD) and 7th (PPVBAT_G3H_CONN((+ve) pin on Battery terminal.
I reset the SMC & turn on the power button. It works.
In OS it shows 64% Battery- and not charging.
After few hours it shows 63% not charging status.
The side button for battery status also blinking 4 led's.
If I turn-off the power supply, the MBP turn off immediately.
The MBP works for 2 days & it stopped working after blinking breathe light once(1sec). Fan also start for 2 seconds & stops.
I thing, direct supply to battery terminals may work if I can give signal to the remaining 4, 5 & 6 pin of the battery connectors. As per schematic it is:
4 -SMBUS_SMC_BSA_SCL
5- SYS_DETECT_L
6-SMBUS_SMC_BSA_SDA
I checked the battery terminal (I opened it) with multi-meter. The battery is not showing anything on all 9 pins. However, the cells are charged because I checked the Cell output terminals (4v, 8v, 12v) & its showing significant output of 3.6V, 6.9v, 11.6V. I guess the circuit of the battery is dead.
por vivek
further, can anyone tell what is the output signal for the following since i dont have any other battery:
5- SYS_DETECT_L
6-SMBUS_SMC_BSA_SDA
por vivek
Exibir mais 1 comentário
