Ir para o conteúdo principal
The Samsung RF25HMEDB is a 25 cu. ft. French Door Refrigerator with separate temperature and humidity control, an external ice and water dispenser, and adjustable storage options. Its dimensions are 35 3/4 in. X 70 in. X 33 1/2 in., and it features LED lighting, a fingerprint-resistant stainless steel exterior, and digital display controls for temperature adjustments.
3 Perguntas Visualizar todos
Samsung rf25hmedbsg not cooling
My Samsung rf25hmedbsg is not getting down to temperature i set. Display and lights come on. No error code on Display and its not in demo mode. Unplugged it for a few hours thinking maybe something was iced over but after checking the panels we don't see any ice. Fan sounds like its on only when doors are closed. Any ideas on what the problem is?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Hi,
What is not cooling properly, the refrigerator compartment, the freezer compartment or both compartments?
The evaporator fan will only operate when both the doors are shut as you don't want to blow any cold air out of the compartments when a door is open. It would take longer then to get back to the set temps if this was the case.
Opening either door will cause the fan to stop if it is running. The compressor will continue to operate though if it is operating at the time.
por
Adicionar um comentário
1 resposta
Solução escolhida
01 - Condenser Coils are Dirty
The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won’t dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty—if the condenser coils are dirty, clean them.
02 - Evaporator Fan Motor
The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
03 - Thermistor
The thermistor monitors the refrigerator temperature and sends the temperature reading to the control board. The control board regulates power to the compressor and evaporator fan based on the thermistor readings. If the thermistor is defective, the compressor and evaporator fan may not run when necessary. As a result, the refrigerator will not be cold enough. To determine if the thermistor is defective, test it with a multimeter. The thermistor resistance should change in conjunction with the refrigerator temperature. If the thermistor resistance does not change, or the thermistor does not have continuity, replace the thermistor.
Part https://www.repairclinic.com/PartDetail/...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
midnightshadow81 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 34
Duração total: 2,122
