Ir para o conteúdo principal
Modelo A1502 / processador 2,4, 2,6 ou 2,8 GHz de dois núcleos / Lançado em outubro de 2013
552 Perguntas Visualizar todos
MacBook Pro Late 2013 Is My Screen Bad?
Laptop works with external display. Is this a bad panel or something that could possibly be fixed on motherboard?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Sadly your screen has failed. You likely sat something heavy on the lid or gave it a good bang along the edge. Here’s the guide MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement The hard part will be sourcing a display as you’ll only find recycled parts and Apple did have a run of displays with bad anti-reflective coatings which makes finding a good one hard and expensive! Here’s one 13” MacBook Pro Display Assembly (L13/14), Apple P/N 661-8153
Esta resposta foi útil?
Pontuação 1
houfuly my response is good, in my opinion, I think it might be broken but you can try to disconnect the screen and connect it again after cleaning the port if that won’t work you might need a new LCD.
Pontuação 0
Adicionar a sua resposta
Fred Flinstone será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 33
