Ir para o conteúdo principal
Um aparelho celular fabricado em 2004 pela Sony.
Flashing red light on joystick
Yesterday, on my ancient but trusty T630, a red light started to flicker regularly. I don’t remember seeing this before. Today after turning it on, the light is gone again. Could someone tell me the meaning of this light? I have looked in the user manual and can not find anything!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
A likely reason, not sure if it applies to my old phone though...
por
Adicionar um comentário
2 respostas
Solução escolhida
Did you charge it before turning it on today? Sounds like a low battery indication.
Esta resposta foi útil?
Pontuação 0
Hi gmantunt,
The phone is turned off and put on the charger every night. It has to be off, because for some reason it has a problem charging correctly if the phone is on. So I don’t think it would be a low battery - the battery icon didn’t indicate it anyway. I suppose it could be a glitch of some sort that resolved overnight? Anyway, I appreciate your taking the time to answer!
Pontuação 0
1 comentário:
No idea what it could be then. Well as long as the phone is working correctly there's not much to fix right?
por
Adicionar a sua resposta
Lami será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 540
